C
Crunchydry
·Guest
I remember a few months ago looking at the Ford UK site. Under the Ford Focus they had the Focus RS which came with a 2.0 Liter Turbo Duratec Engine. I recently looked at the Ford UK site and saw that the Focus RS was removed from the line up.
I know that the engine is produced in the UK but since it is a Duratec I was wondering if anyone knew if it would be plausible to do an engine swap or even possible to go through ford and order this engine. If I remember correctly, the turbo kit for the V6 costs in total 5K, so money wise it might be cheaper to get the factory motor. Especially if you could find a slightly used one.
The motor puts out 214 HP and 228 Lb. Torque.
I think this might be a very worth while upgrade because, although i am impressed with the HP gains of the 3.0L SVT Hybrids, i do not like the idea of adding extra weight to my car and taking away from my cougar's handling or breaking ability.
I also rememberer from Ford UK that the 2.0L Turbo Duratec is aluminum compared with the Zetec's cast iron and the turbo is not a bolt on but integrated. I believe that the weight of the 2.0 Duratec with the turbo would probably be comparable in weight to the 2.0 L Zetec. In that case the car would have have a 60/40 weight distribution compared with the 64/36 of the V6 (if my math is right ). It would also have a power to weight ratio of 13.2 LB/HP opposed to the stock MTX V6's 17.3. Put in perspective, this engine would give us a better power to weight ratio then the WRX 13.6 LB/HP (3085/227) :biggrin:
Here's a link I found on the Focus RS.... too bad the RS is no longer on the UK Ford site. It had much more information. Link
