1 - 2 of 2 Posts
yesterday i was putting on my obx/kkm pedals and i got my clutch and brake on no prob but for some god who knows reason i couldn't get the gas pedal one on (yah i sound dumb) do any of you know what drill would be the best to drill a hole in the stock pedals so i can screw it on? (the bottom clamps won't hold them on alone)
The gas pedal is a plastic pedal so any drill bit will work, as far as which bolt/nut combo to use, you'd be better off with a flat screw that uses an allen wrench, and a silicone lined nut. That's what I have holding on my pedals (they came with the hardware), and I haven't had a problem with it. If you try drilling through the clutch/brake pedal you'll need a metal bit, just FYI.
1 - 2 of 2 Posts
