im looking to install an alarm but i need a diagram.if anybody has one and could help me out please hit me back.THANX
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|gray/white |+ |ignition harness |
| IGNITION|green |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|yellow/green |- |drivers kick panel |
| POWER UNLOCK|white/green |- |drivers kick panel |
| LOCK MOTOR|yellow/black | |drivers door harness |
| UNLOCK MOTOR|white/black | |drivers door harness |
| DISARM DEFEAT|white/green | |passenger door harness |
| PARKING LIGHTS +|red/blu & red/yel *5| |headlight switch |
| PARKING LIGHTS -|black/yellow | |keyless module *1 |
| DOOR TRIGGER|blk/red & blk/grn *2|- |top of the fuse box |
| DOME SUPERVISION|black/blue |- |drivers 'A' pillar |
| TRUNK/HATCH PIN|black/orange |- |drivers running board *3 |
|TRNK/HTCH RELEASE|black/yellow |- |at switch or drivers kick |
|FCTRY ALRM DISARM|black/white |- |drivers kick panel |
| TACHOMETER|brown/green | |ignition coil pack |
| SPEED SENSE|white/blue | |*4 |
| BRAKE WIRE|orange/blue |+ |brake switch |
| HORN TRIGGER|black/blue |- |ignition harness |
| LF WINDOW UP/DN|wht/pur - yel/pur |A |drivers door switch |
| RF WINDOW UP/DN|white - yel/grn |A |drivers door switch |
Notes:
NOTE: This vehicle is equipped with PATS (Passive Anti Theft System).
Use DEI module 555F to over-ride during remote start.
*1 The keyless module is located behind the glove box. This wire flashes the hazard lights.
*2 Use black/red for the drivers door and black/green for the passengers door. Diode isolate each wire together to the alarm. To access these wires, pull fuse panel down and remove cover.
*3 Towards the rear of the running board.
*4 Located between the firewall and the strut tower on the drivers side of the motor in a 10 pin connector.
*5 These wires must be relay isolated from the headlight switch to keep the headlights from flashing with the parking lights.
