1 - 3 of 3 Posts
ok. Here is what is happening. My ATX slips occasionally in first gear. Meaning from a stop I rev it (while in drive), but it isn't in gear. I have to let it rev down and hit the gas again for it to get into 1st. Also on a regular basis I get on it and it will be in the wrong gear. Like from going 10 MPH I get on it and I am in second or third and I have NO POWER. I have ruled out secondaries failing. I do need a new front engine mount but not the tranmission mount (or whatever it is called).
One more thing it does if when I switch it from Park to any gear it jumps (DOES NOT shift smoothly)
Please help because my warranty is up soon and I need to know what I should do.
Thanks a lot
Mark
Sounds like what happened to me when my tranny went out. It was the front clutch pack assembly and drum. I believe.....could be off on the wording.
If you still got a warranty, take that in regardless. If you dont and it breaks, you're looking at a $1800 job, least what my retarded dealership quoted me.
Are you throwing any CEL's or anything???
No CELS bu I am throwing soem kind of "trans sensor out of range" or something like that
1 - 3 of 3 Posts
