You mean you want all your interior lights on at maximum brightness all the time, and have no control over the brightness? Yeah, you can do that, just disable the dimmer switch. I'm assuming by doing that then when you turn your lights on, since there is no dimmer switch in-line with the lights, then they will just be on at one brightness. I'm not sure if you can just pop out the switch and disconnect it though, I don't know if that switch completes a circuit or not. You may have to do some alternate wiring to bypass the switch instead, I'm sure someone on here knows.
