Also called a cylinder head, the head sits on top of the engine block. Being a V6, the Duratec has two- One over each bank of three cylinders. It basically covers the pistons, and is where the valves, spark plug, and cams reside. Big part of the engine. The heads are responsible for getting air into the combustion chamber, igniting the mixture, and purging the exhaust gases. Any inefficiencies in this process technically rob you of horsepower. The stock Duratec is meant to be a daily driver engine, not a BTCC engine. Leo Capaldi did TONS of work to his SVT spec motor and is pushing 300 normally aspirated horsepower. Granted, this is on racing fuel and 13.0:1 compression. Port & polish, lightened flywheel, forged crank, titanium pistons & rods, custom cam grind- The works.
Hope this helps,
