Well, we have Jscull...shipping us the lights.
On the 2001 lights it was very similar to these, and certainly it does appear that we need to do some creative installation.
The inner ring appears to be too big, so the our factory will need to produce a smaller ring <--- WHAT?!?!?!? no cover up? no, we're going to make them fit? A true statement? Ok, everyone, you can get up off your duffs and glare at the screen some more and run around with the banter I hate...whatever you have that day.
So, joking aside....
The reason one of the rings doesn't light up fully can be related to one of 4 things:
1) They are pretested before shipment, as this is one of the ones that was pre-tested and shipped to Q4. So, it's likely that it's very cold or...
2) The two wires running to the ring are touching <-- likely because the ring is partially lit and this is the first sign of "arcing" between the two wires. @ 500+VAC it's a lot of voltage or...
3) The ring cracking during shipment or during install, though this is less likely.
4) And this is possible, that during some part of the install - again, this isn't about finger pointing but facts that we've acquired with over 100 installs PERSONALLY attended to - caused a short somewhere on the power ballast where it's dividing its power incorrectly. If you were to disconnect the one ring that is lit and fire up the other one with that connector, you should see good results if the ring is fine.
As for exposed wires, I think it's Q4's desire to avoid breakage and persevere through the install without complete instructions that causes some of the exposed wire. In reality, that wire is almost too thin and when pull taughtly, is completely unobtrusive and nearly invisible - we are however specifying that in the future all our wires will be silver in color.
Any other comments are indeed welcome, but once the 99-00 headlights arrive here, we'll have some immediate pics on the site.
For those of you on the fence, you will be satisfied, for those of you not on the fence, and in the "game", then we will certainly offer you the benefit of early buyers which we will determine shortly after the final installation is done on 99-00 lights.
