What exaclty is done when you get your dashed dyed??? is it the same thing as painting ????
G Guest · Discussion Starter · #1 · May 8, 2001 What exaclty is done when you get your dashed dyed??? is it the same thing as painting ????
PuckPuck · T3/T4 60-1 Joined Oct 16, 2000 · 8,015 Posts #2 · May 8, 2001 Only show this user you paint it using body paint.... however there is a special flex primer you should use first....
