Hello and welcome to NECO. Go to the how-to forum and find the stickied thread at the top that lists a bunch of how-to's. Crispy wrote one that is on Teamneco.com and is linked to in that thread. Unless I'm missing something, to get to that piece you have to remove the dash pieces on either side of the steering wheel, there are 5 (?) torx screws holding the shroud in place, and it is basically popped in in the back, so use a screwdriver and pop it out! The rest of the dash is a combination of screws, but torx is very prominent. The stock radio MUST come out to remove the center piece of the dash, as there are two screws placed vertically above it. Take your time, and be careful and you won't break anything. Also, disconnect the negative battery cable, (black) because you will be disconnecting and reconnecting electronic components. Hope that helps.
