Guest
·Okay...just installed the v-tec covers on my tails tonight - look very sweet. Only problem is a little "glow" around the perimeter from that one annoying little light (not either of the two convex lights, but the other one). First question - how do I go about getting to that bulb so I can remove it? I did a little looking tonight and I assume that I need to pull back the "carpet", un-do a couple of bolts and remove the bulb. Is completely taking those bulbs out a bad thing? And my last question: How in the hell do you get the little black plastic rivet-like things to go back in??? I popped one out tonight with a flathead screwdriver to avoid tearing the carpeting, but I'll be damned if I can get it to go back in... Any advice would be greatly appreciated.
