1 - 10 of 10 Posts
I assume you have an ATX and V6? Did you take all of the things that you don't need? Subs, spare tire, any other things that might be lying around? Rim weight makes a huge difference too. Atleast you had an excellent RT.
well...everything was still in the car b/c it was a "at the moment thing" do u think it would made a diff if id took all that ......out yes it is auto and v6............ i was plezed with my RT also...i also had the AC fuse out.... i manully shifted my first 2 runs those where almost the same my 19 came in when i stayed in drive and dropped OD...i also dropped OD when i was manually shifting.....
It would have made a difference, maybe not a huge difference, but a difference. I forget the equation, but it seems like every 100lbs taken off the car lowers your times by 0.10 secs.
1 - 10 of 10 Posts
