No.
The stock Cougar springs are already essentially SVT spec to begin with.
And KYB struts are not much different from Cougar OEM struts.
So unless you're replacing worn out parts, you won't see any change.
No.
Are they even compatible? I was under the impression that they're completely different.
Are what compatible? Contour springs on a Cougar? Yes, they're compatible. Other than needing 99/00 rear spring seats on 01/02 Cougars.
Im just trying to get a lower stance and a little more handling out of my ***** without having to mess with camber adjustments, and not blowing a few paychecks on going full out with some extravagant system.
