1 - 2 of 2 Posts
I was just wondering with my clutch I dont know if it is gone or if there is a way to adjust it because the pedal only has about a half an inch of clutch play in the top so it is a pain in the ass to drive in smothley because it is basiclly on or off! The clutch does not slip at all so thats the only why iam thinking it is not gone but I will leave that to the experts on this (you guys)! I know its a hydrulic clutch but is there a resevoir for clutch fluid or is it in the master cylinder? do i need to add clutch fluid? will that adjust the pedal?
Thanks
You can bleed the clutch first then refill the resevoir...and see if it helps
The resevoir for the clutch is shared with the brake resevoir...it's the same resevoir...however that's the only thing the 2 systems share.
1 - 2 of 2 Posts
