99 V6 ATX 104K mi.
So whenever I back up in any direction other than straight, put it in drive, push OD off button, turn the wheel and go, I get a crazy clunk like I ran over a huge rock. Is this a tranny problem or something else?
I would suspect an axle or CV joint maybe...
Does it make the same sound when you put it into Drive, but have not backed up first? If not I'd suspect what Bennett did, sounds like excess play in axle or CV joint (reverse puts all the "looseness" one direction, then when you go forward it clunks back the other way).
