1 - 14 of 14 Posts
How to Clean the IMRC:
Tools needed, 1/4 inch rachet and short extension. 7mm socket ( I AM CANADIAN ), medium sized phillips screw driver. Flat screw driver. Permatex automotive silicon seal, your colour choice. Silicon sealant is optional but I suggest using it.
1. Remove 3 bolts holding Duratech plastic cover in place.
2. Remove 4 screws of IMRC cover.
3. Carefully pry cover off case.
4. Using air in a can or filtered compressed air, blow out the case.
5. Gently lift motor so its gear disengages and support it with something non-conductive. ( I used a piece of tree twig , was close at foot :) )
6. Spray motor with cleaner ( make sure it is safe for small electric motors.
7. Apply power ( negative and positive to board and let motor run 15-20 secs. Positive is top left on board ( red wire underneath, and negative is bottom contact, black wire underneath.
8. Air clean once more and using clean rag and q-tips clean and liquid out of case.
9. Lightly grease gears with a high temp light grease.
10. Apply a smearing of silicone sealant to cover ( to keep out moisture ) and set cover in place.
11. Replace cover cover and tighten screws. Wipe all araoung cleaning up over spray, sealant, etc.
12. ReplaceDuratech cover and tighten 3 bolts.
13. Go have a cold one, you are done, car is ready to RUN...
:bowdown:
Discussion Starter · #2 ·
My IMRC on my early 99 only gets stuck closed when the engine compartment is hot or the box with the motor is.... Will the clean help any? Or would I be better off to just purchase a new IMRC from fpo
I was told I need to do this. Can somebody post some pics of the IMRC, I have NO idea what it is. And what does it do? What does IMRC stand for?
Look at me! Look at me!
IntakeManifoldRunnerControl
And it handles the opening and closing of your butterflies.
You guys got me curious, so I checked mine out last night... Clean as a whistle at 70k... ? I guess that's good news.
So, you are recommending we drink and drive?
haha jk, thanks for the how to
Possibly fail to open your secondaries at 4500 RPMs ... you wont feel that minor kick at that level and you will have little high end HP... I think youll also run realy rich at the 4500+ mark since the engine will poor enough fuel in for the secondaries to be open but with out them open youll get half the air you need for the mix.
im about to do this, but will it void the warranty??
what are the ideal products to use for this prodcedure? i have a can of electrical component cleaner in an aerosol, is that what you recommend? also, you mention a high temp light grease. can you give an example of what specifically constitutes a high temp light grease? and for giving power to the motor, will a nine-volt with a couple of wires attached do the trick, or should i run it from the car's battery?
thanks.
1 - 14 of 14 Posts
