What i've got here is a 396 machined to a 402.
Casting # 3969854
Block Casting Date e7-71
stamp assembly code - t0609tkb
2 Bolt main block
Cast heads # - 3986133
One of the heads needs new valve springs and retainers. motor also needs a Crank and possible new rods due to a spun bearing. All in all the motor has about 15 minutes on it after machine shop work. oil pickup line moved resulting in bad oil pressure.
Comes with :
Flexplate
Professional Products Dampener
Brand new stock oil pan
New Melling oil pump & pick up
Hei Distributor
other misc items.
Asking around 700 O.B.O.
Personally the internals on this engine are like brand new. The cylinder walls are smooth as could be.
