Figured this is worth a PSA seeing these cars are now 20+ years old now.
I just pulled apart 4 headlights, all factory sealed, and the wires that lead to each hi/low beam bulb no longer had a coating. The copper was exposed all along the wiring at different points and could easily ground against itself or the headlight internals.
Only solutions I can think of are to give them a coat of liquid electrical tape, splice new wiring, or replace it entirely with new pins. Mine is at the point the entire wire should be replaced.
80769
You can also buy the plugs with wires attached on rockauto. Headlight pigtails basically
  • Like
Reactions: JScullin
Yep those. One of the bulbs is a 9005 and one is a 9006.
The Contours have similar issues but with the entire engine wiring harness. Ford issued a recall on the 95-97's to replace it. The 98-00's still had problems but were slightly improved. I've had a few issues with my '98. Liquid electrical tape FTW although I still need to direct wire one of the O2 sensors.
3/5 of my headlights are fine. Of course the two that aren't are the ones I want in the car... I'm paranoid from working in computers/servers where the littlest thing could cause irreparable damage so I always recoat damaged sheathing. Strange that it would be the 02 lights when all three 99s are fine. Fresh in my mind because I just redid the turn signal sockets with one that will fit all the housings.
