Discussion Starter · #2 ·
Don't know but the guy at the dealership said I needed a special tool. You think I can go a ways past 15k miles before I change mine?
You only need a screwdriver
there are 2 plastic clips that you remove (and they are only used once) and a metal worm clamp that holds the filter in place
Check your manual for what fuse to pull (fuel pump) pull it and run the car until it stalls.
Get under the car with a pan, and there will still be fuel that is pressurized when you remove the clips and hoses.
install new one and do the reverse steps
