Yeah, I have the same emblem as ShinyBlackCat does there in his signature pic. The carbon fiber looks SO much better than the stock Merc emblem - especially against my zinc yellow paint. The emblem is slightly larger than the stock one, but that doesn't bother me a bit. If you're gonna do this mod, it's super easy. Just try to apply some heat to your emblem with a hairdryer. That should soften up the adhesive tape and make it easier to remove. I used dental floss to "saw" the emblem off, but I think it would be much easier to use fishing line. It still won't hurt your paint, but it also won't fray - floss obviously does. Use a product called "goo-gone" to get the rest of the adhesive off once you've removed the merc emblem. Just remember that it strips all the wax off, so you'll want to make sure you re-apply some of that. I also heard that peanut butter works in a similar way without stripping wax, but I wasn't ballsy enough to actually try that. Anyway, the same process goes for removing your "c-o-u-g-a-r" and "v-6" letters if you so desire to do that... Best of luck!
