About a week ago my coug wouldn't start after putting some gas in it AND THE DAY BEFORE I HAD TO GO TO CALI WITH IT. It made that click when I tried to turn the ignition which usually means that the battery was dead. But the lights and everything electrical worked fine so we thought it was the starter. AFter a few hours me and my dad were able to go get a new & bigger battery & we cleaned the plaque off and it finally worked. Problem was that the old battery still was good so I couldn't have been that. So we went to check it at Autozone and Napa for everything and they couldn't fine anything wrong w/ it. So we thought it was good now so we went to cali. What happened, bam once in LA after doing some stuff same thing happened. We had to wait around and check the unknown area to get some help, luckily we got a tow truck late and took it to a mechanic which found out that a cord around the bottom of the car was disconnected, and that the started wasn't tighten enough so he did that and the car worked. Now after that we thought it was finally over. WRONG just thursday and last night the car almost did the same thing again, but luckily on the second or third try of turning the ignition it worked, but I'm getting to the point where I don't want to drive my tight coug anymore so if anyone has had something similar to this and has fixed it, please tell me how.
Also just incase this is related I have a atx 2000 v6 cougar, everything is stock performance and engine wise, but I have neon lights and the fan angel light mod connected to the same transporter and switch. I forgot who but they told me to buy a 40 amp relay and just connected anywhere in my fuse box to I guess stabalize the neons & angel eyes, but in the only place I could put it made the side headlight lights stay on. I took it off thinking this would drain my battery faster, but considering all this should I put it back on to see if i'll help or replace another relay with it?
Sorry for writing so much, but I wanted to be as specific as possible w/ my situation to see if anyone has had the same problem and can help me out. thank you
