bah, just look at your final tire size to determine if it will fit or not... if your going with 225/35/18, your diameter in height is 24.2 inches, while my stock tire 205/55/16 is 24.9" tall. The new width of your wheel will be 9.1" compared to my/your stock width of 7.8". So techically your going only 1.3" wider with the new wheel/tire combo. Which equates to .65" on both sides... plus the extra 22 mm offset. To my calcs you get something that sticks out only 38 mm more, and not 46... so 38mm is equal to 1.5" rounded up. IMO this extra 1.5" will really fill out the gap, and make the wheel equal in width to the fender. you should have no problem clearing the suspension.
