I have the Terminator sides....at the tops they bow out some I wanna mold them so they dont stick out can i use Bondo Fiberglass to do this?
· Banned
you need some sort of panel adhesive to fasten them first like fusor 147 or duramex 4188.
if you dont use the adhesive they will flex and your mold points will crack. after that sure the bondo would work. most autobody ppl would probably recommend another line of products such as USC or my personal favorite Evercoat but its just personal preference.
· Banned
any place that sells body shop supplies either online or local should carry one or the other. you can even order the fusor from krazykustomz its about 50$ a tube and the same for a dual cylinder applicator gun. 1 tube should be enough for a pair of skirts.
· Read Only
get fusor 147 and put it between the skirt and the body of the car, and put in stainless steel self taping screws to let it cure over 24 hours. To fill and make it look molded you should probably get some duralgass or everglass and fill in the edges, and feather it to make it look stock, sand it, apply some rage extreme or light body filler, sand that, then glaze it, and sand that and primer it. Thats a pretty basic decent how-to. Get crispy to chime in, shes the one whos given me all the advice on my bodywork.
It may sound easy, but body work is a little harder than it seems, trust me ive started to do my own... but you could do it yourself, it takes patience, long hours and dedication.
