I made some of these for myself because i did not want to spend NPG prices.
After having a bit of interest shown on the facebook groups i decided to offer them for purchase.
Keep in mind, i am making these by hand.
Kits i have available:
300mm Front (SVTF front rotor)
300mm Rear (SVTF front rotor)
278mm Rear (Stock SVTC or sport? cougar front rotor)
Kits are $100 shipped each in the states
Kits will come with all hardware, unpainted.
Rear kits will require some work for fitment by the purchaser, the rear caliper bracket needs widened on the inside because the front rotors are wider than a stock rear rotor, Also, new brake pads will need shaved down as everything will be too thick for the caliper to fit around.
I might have the wrong imgur links but i will fix after post is approved.
