1 - 9 of 9 Posts
Hi from Spain!
I'm coming to install a BZ short RAM intake, and I'd know if somebody with BZ had installed a WR cold air box.
The BZ intake:
The cold air box:
Does It fits correctly?
Any picture of this cold air box installed?
Thanks!!!
I doubt any one does as the BZ intake looks like one of those ebay peices of crap. I would also figure if anyone is spending the money on the cold air box they would also get the WR intake also ...
outside guess, if the filter/maf end up in the same spot as the WR intake it should work
This is my BZ intake installed:
I have heard lots of complaints about the WR "cold air" box. It pretty much just serves to choke off the airflow, and the aluminum heats up a lot more than the stock plastic box, and just holds it all in!
You'd be just as well off using your stock plastic airbox and a K&N drop-in filter, along with the metal intake tube. At least it draws air from outside the fender.
1 - 9 of 9 Posts
