Originally posted by: unisys12
Originally posted by: BrantlyJ
The manual tells you exactly why those two gears are there. 2nd is for going down a step hill and you want to use your engine as a brake instead of using the standard brakes and possibly overheating and warping them. 1st is for climbing large hills or for when you need a little extra torque and don't want the tranny to shift out of first gear.
This is not some shifttronic tranny or what ever they call them. You will do nothing but decrease the life of your tranny as all it will do is cause it to heat up the fluid and torch it. All the while giving you a false sense of you actually having a manual while you do your ricer shifting.
There is this thing out there on the market that you might not have heard of. It is called a
Tranny Cooler.
There is also some great fluids out there, like Mobil 1 Syn. Would you believe both of these have proven to
drastically reduce ATF temps.
As for it being an electronically controlled unit and we should all bow to the cause, well that is just plain simple... well I wont go there. Come on. You can't truly claim that as a reason. If that is your argument, then I hope you don't have a chip in your car. Nor thinking of buying one, because your PCM was programmed a certain way for a reason.
I hear ya on the overheating issue's, but... I think you will have to give me something a little better then yawl's claims to ghey and rice. Sorry.
