On my cluster, whenever i start my car now and start driving, the light for the parking brake goes on when i make sharp turns or fast shifts.... anybody know what this is?
So its begun.....
Check your brake fluid level..You may need just a little
Discussion Starter #4
Well, since i just got that now... its a little late, but my brake fluid resivour was more than halfway to min. so i filled it up and the problem went away.
The problem was with the brake fluid level. When you made a hard corner the fluid would dip below the sensor making it think that there wasn't enough fluid. The windshield washer fluid will do the same thing if it is about a 1/2 tank or less.
