K
kodyvan19
·Guest
Is there a how-to on moving the battery to the trunk? I DID SEARCH.
ACKOriginally posted by: GrandMasterKhan
Its basically the same as installing an AMP in your trunk.
I used 2 car audio power distrbution blocks in the engine bay to feed my powers and grounds into their own respective 2 gauge wire.
The negative grounds in the engine bay to bare metal on the frame.
The positive should run through the firewall and down one of the sides of the car under the carpeting to the battery.
Then ground the battery in the trunk to bare metal.
The Summit racing kit will come with instructions and everything you need for install (except no nice pretty power dist blocks like i used)
