I am in the process of relocating my battery to the trunk and am running into a problem. Everything is hooked up and working, but when I turn the car on I have really loud line noise. This is obviously from a bad ground. This is how I have it hooked up right now:
I have the power wire running from the stock wire in the engine bay through the car and hooked up to the battery in the trunk.
The grounds that were previously hooked up to the battery in the engine bay are now grounded to the wheel well area through a hole I drilled in the metal. I ground the area down to bare metal of course.
The battery in grounded into a hole I drilled in the truk floor. I also ground the area down to bare metal.
My amp was previously grounded to the trunk floor, but I moved the ground wire directly to the negative terminal.
After the line noise I moved the amp wire back to where it originally was... This didn't solve anything. I also tried to run two grounds from the negative terminal... This also made no difference.
When I turn the car to the on position (not started, but the accessories work) it makes a really loud line noise. I need to get this fixed ASAP!!! When I did a search I read a post that said that the ground had to be hooked up to the original place in the engine bay... The battery relocation kit that I bought came with a ground wire that is only like 12" long though - so this can't be the case! I don't see what the difference would be! Please help!
