1 - 3 of 3 Posts
Moved my cougar to my new place and parked it for a few days. went to start it for a wash and battery was dead. exchanged the battery, installed it and went to start it. it started sputters and stops. i just spins now but will fire with starting fluid. broke out the scanner and had the normal drive cycle codes but a new B1681 code. took a look at a few posts here in the forum and was able to verify that the fuel pump is good.
Broke out forscan on my laptop and dropped in all the Pats markers into the logger and I'm needing some confirmation.
The pats enabled status is disabled. can't figure out if that means that the car is disabled or that pats is disabled. I can say the indicator light flashes continuously on initial key on., but when i try to start it, the light stays off.
can someone verify what disabled means for the pats enabled status and/or if the flashing indicator means that pats is just screwed up.
its sitting in timeout without a battery for the time being.
PATS light flashing rapidly or continuously on are bad. Off is good.
Does it jump start?
1 - 3 of 3 Posts
