I got a 2001 merc cougar 2.0l 5 speed, my axle is going bad and I can't seem to find the right axle the ones I keep finding are 27 output but mine is 33 output spline and 38 on the back!? Can anyone drop a part number or why mine is different from the stock axle or show me which one I actually need no abs just trying to find the right axle. I also forgot to mention the input into the transmission is a female inlet
Thank you.
The rusty one in the photo is a right side axle, the other photo shows the left side of the transaxle. Which side are you looking for?
The right axle doesn’t go into the trans, it connects to a jack shaft behind the block. The left axle DOES go into the trans, but it uses a decidedly male end.
If you don’t have ABS, you can still use an ABS axle. In fact, you pretty much can’t get NON-ABS axles anymore for that very reason.
