Originally posted by: tropiccougar01
Why would you add time? Your reaction time doesnt affect your ET. It just helps determine whether you win or lose the race.
Do NOT get a g-tech if the main purpose you want it for is the HP ratings it gives. I have the g-tech Pro and it is pretty cool for 1/4 or 0-60 times. But when you dyno a car the car is sitting there, with the g-tech you obviously have to be moving. and it states in the instruction book that since wind resistance is a HUGE factor your HP readings will be very low. For example i put down about 158 FWHP on a dyno. But the g-tech said i only had ~130 HP. So it is very misleading to say the least. Anyway goodluck with your decisionOriginally posted by: VHull03
edit: how close are the horsepower numbers that it puts out???
FWHP = FRONT Wheel Horse PowerOriginally posted by: JohnnyRed
yea, it said I put out about 130 to the wheels as well.....you say the dyno said 158 WFHP.....are you sure you don't meen to the wheels because that is um, less than what you started with
