So my engine that was supposed to be finished several weeks ago, was just given back to me on Friday... effectively preventing me from getting it in the car anytime in the next few months :disgust: Not only that, but of course there are several things that weren't done correctly on it...
First of all, even after I told them every time I talked to them, they still didn't remove the bushing from the end of the crank... which I asked them to do before they balanced everything ... and when I pointed this out to them, they took an air chisel to it while it was sitting in the back of my jeep and popped it out. Now I know this isn't a major part of the rotating assembly, but knowing they spent 13 hours balancing everything, I'm worried that this is going to throw it off. Thoughts?
Secondly, they never filled the oil feed hole and just did the return lines... so I'm going to have to JB weld it along with the set screw I already tapped it for. Just another annoyance added to the list...
Thirdly, when I dropped off all the main bolts, rods, etc for final assembly, I brought the instructions for where to put the studs for the upgraded windage tray... and they told me they didn't need them because they had gotten them from Ford already
So I come back to pick it up, and they had gone out and bought a Chilton's manual for 95-2000 Contours and Mystiques :disgust: and not the Escape like I had told them several times... so now the windage tray doesn't fit, and I will have to buy some more of these lovely one-time-use-TTY-$3-a-pop-bolts...
So is the best method for replacing these to just pull them out and replace them with the correct ones one at a time?
And on top of everything else, they tried to charge me almost twice what my original quote was for without ever telling me it was going up. And I'm not about to pay $1500 for something they didn't even DO correctly
