I just removed the restrictor from my air box. I only took the top piece off for now. Am I supposed to take off the bottom piece that snaps in? Also I keep hearing people say take something off the fender. Dumb question but are they talking about the rubber thing that attaches to the drivers side-wall of the car, directly off the air box, leaving a hole in the air box? Just want to make sure so I don’t screw something up.
Thanks
You dont HAVE to remove that piece inside the airbox, although I did. I also removed that rubber hose. Makes the car sound powerful at higher RPM's and when there is enough 'strain' on the engine to cause it to suck in air such as going up steep hills at slow speeds.
removing the rubber boot will make the intake much louder. that's about it. althought it will suck in lots of bugs and dirt. clean your filter often.
