how would you people suggest i stabilize my weapon r intake from moving around slightly. i am not using the weapon r filter, i got a k&n filter on there and the mounting bracket for the intake is on the weapon r filter. so a suggestion or two would be greatly appreciated.
use a 4 in exhaust hanger it works great and you can bend it in many directions to fit your application.
okay thanks for that lil bit of info! but i have another question. where should i mount both ends of it to?? i definately got to get something to stabilize it soon. it don't look like the speaker wire i have holding it down will last much longer :shrug:
Do you have the nice shiny tube are the factory rubber one¿
I just put a KKM filter on the factory rubber hose and the filter pulls itself down onto the wheel well. So I put a foam strip down with some 3M double sided sticky tape. It doesn't stop it totally from movement but it shure helps.
