A lesson learned: A tale of warranty denial.
Not sure if this will be helpful...or just funny.
People around here ask this all the time, "will ______ void my warranty?" Well, here is a fine example of what can void your warranty.
Customer brings 01 Ranger in today, headlights not working, other electrical issues. Truck is still under 3/36. Well, first thing the tech sees is an aftermarket headunit, and decides to check there first. Removes headunit from dash, and takes a look at the fried wire harness. Knowing that there is still something else amiss, for a bad headunit will not cause you to have no headlights.....he continues pulling the dash apart. Well, he gets to the headlight switch and dimmer switch, only to see that the harness leading to those switches is also fried. After he removes most of the dash, he sees the whole picture...the entire dash harness is fried, in many spots. So he examines the radio harness closely.
Whom ever installed the radio, decided to use the "cut and splice" installation method. Well, there were some straglers peeking out through the electrical tape splices, and that is what caused the burn out.
Warranty claim OBVIOUSLY denied, it becomes a customer pay issue....including the two hours for diag. Total cost of the repair $5000!! Dash harness, labor for install, labor for diag...totalling around $5000.
Customer has not decided what he/she wants to do...and is VERY upset that it is not covered under his/her 3/36 warranty. But that is what you get when you decide to have a friend do a crappy install of a headunit. Imagine, a correct harness to install said headunit is roughly $10....and that would have saved him/her $5000.
Lesson learned. If you want to modify your car, do it correctly. Do not cut corners....and make sure you can undo anything you did.
