Leibler and I have been conversing a bit in PMs about some things and I think it would be a good idea to post them here and to further discussions on the board as opposed to in PMs so this info can be avaliable to everybody. I asked him if it would be ok to post our PMs and he said ok. Here they are.
leibler
Seawulf,
You like the Focus SVT pump over the stock pump in our cars, right? I think mine is dying and while I have the car on blocks the next month I think I'll replace it (along with everything else).
BTW, here's my post on the pump:
http://www.fastcougar.com/forums/messageview.cfm?catid=5&threadid=90690
Seawulf
The Contour SVT fuel pump is a more direct bolt in since the Contour and Cougar share the same chassis and drivetrain.
It does take a little modding to makeit fit but it's a common fuel pump upgrade on the Contour forums and costs around $75.
leibler
Lee,
I have two question for you.
1 - when you go to larger injectors do you have to upgrade your fuel pump or will the stock one still work?
2 - I talked to Pro-M and they can do a meter for me, similar to how they did yours, but they said the following:
"Yes we have a 70mm for the Focus. My only question to you is that these meters would be 6-pin and I was under the impression that the Cougar was still a 4-pin. Although, if you are sure on the calibration and specs, we can match anything for you."
Ours does appear to be a 4-pin. How did you deal with this problem?
- Adam
Seawulf
The reason you get larger injectors is so you can run the larger injectors at the stock fuel psi. 42lb/hr injectors will give you twice as much fuel at 45psi as will 19lbs. So you shouldn't have to run a different fuel pump unless the stock pump can't keep up with the fuel psi. So you could go ahead and swap in a Contour SVT pump, but you won't know for sure until you're boosted if you need to.
My MAF is a 6 wire MAF. If your MAF is a 4 wire then...I don't know. Are you sure yours if 4-wire? The obvious way to tell is to look at the MAF is to count the numbers of wires comming out of it. How are you going to tune the car? You may have to get a stock ford oem 4-wire MAF off a mustang and have your tuner figure it out.
liebler
You're right - 6 wire on my car as well. I looked at a few other Cougars over here and all the Zetecs I checked have 6 wire.
And thanks for the fuel pump info.
Lee,
Keith at Pro-Flow wants to know if you have your flow sheet for you rMAF. He said if you coul de-mail a scan of it to me, he could make me a copy in just a few minutes.
Just wondering
Seawulf
I don't have the flow sheet anymore. I got what Turbo Tom recommended, but he's since gone into more detail on what it is. The new SCT tuner software has values for stock oem MAF calibrations so you can just select a type of MAF from a chart, so he said this on the Focaljet:
Quote
I dont talk much about tuning so i didnt give some of our hard work away but this new tuning is coming out and is so user friendly ,,I have allways calibrated the mass air to a code of COB30 for 42`S this is what we use in out kits
What COB30 is a ported "recalibrated" Mustang Cobra mass air set for 30LB injectors this with our ability to change the transfur functions makes the range on both the injectors (1-100%dutyclcle)and the mass air (o-5 volts)very close
Tom
leibler
Seawulf,
Seawulf
leibler
Lee,
- Adam
Seawulf
liebler
Lee,
Just wondering
Seawulf
Quote
Tom
