Hello all,
This is my first post. I'm a new Cougar owner, actually by accident...I just returned from Iraq and purchased a new home for the family, I also needed a new car to get to work but with the mortgage in process of closing I couldn’t touch the credit so I went out and bought what I could afford with cash...turned out to be a 1999 Cougar V6.
The car looked good but was scary to drive over 40mph...2000 dollars later and new outer tie rods/struts/rotors/calipers/pads/spark plugs/air filter/cabin filter/fuel filter/oil change/new tires (215/35r18)/new 18" rims/alignment...(takes deep breath)...now the car drives like new! I did all the work myself minus the alignment and tire mounting (rest in peace to two socket wrenches who died dislodging the strut pinch bolts :banghead
. Just a few more problems to fix.
Problem #1: A/C tested mechanically sound but was not receiving any electrical signal to turn on.
Problem #2: The vent control always goes to defrost. But if you start the dial on defrost and slowly work it around to forward vent it will blow air out the front vents...that is until it decides to go back to defrost or if you turn off the car, on restart its back to defrost again. Sounds like a vacuum issue to be.
Problem #3: Rear hatch will only open if you assist it while unlocking it. The struts will hold the weight of the hatch up but the lock mech seems to not be strong enough to push the hatch up and out of the lock. The two springs on the hatch seem okay.
Problem #4: I also have that rev problem that some have talked about where when you go into neutral after driving in a gear for a while the engine will rev to 3000-4000 rpms for a second or two then come down. Some post suggest this is normal and others think it’s a vacuum or IAVC issue. I'm not sure myself.
Problem #5: The lights in the overhead console do not function. I'm not sure yet either they where intentionally disconnected by the prior owner or faulty. I haven’t even investigated this issue yet.
Problem #6: The headlights are greenish yellow inside in the lens. Is there any good ways to clean and polish the insides so that they are clear again or in replacement the best option?
Problem #7: The car needs lots of paint touch ups and the ground affects have seen a few too many curbs-the fiberglass needs crack repairs. The paint code NE seems to be difficult to matchup. AutoZone only shows the NE code as being for vehicle years 1995-1997, the code disappears for later models.
Problem #8: Horsepower, honestly who couldn’t stand to have just a little more?
:bowdown: Thanks for any input and suggestions. Any other cougar owners from the Washington state area?
WTB: 1999-2002 center console, 1999-2001 headlights, clear side markers, dash board (the center piece that starts at the driver side and surrounds the heating/cooling knobs).
WTS: (2) 18" rims 4x108 universal, (2) factory 16" rims 4x108 with tires 10-20% tread left
