1 - 17 of 17 Posts
Hi All,
I have just been referred to the bard by Bill Jenkins, and have a question... in a few parts.
I have done some mods to my 99 Merc Cougar, 2.5 v6. It now has an AEM short-ram Air intake, a custom Cat-converter by Random Technology, and a dual pipe exhaust by Remus.
At high revs, she does very well, but at low revs and when I put my foot down from an idle, she chokes... like its too much air for her to handle.
Can anybody give me a few options? Mass air flow upgrade? If so, to what?
Thanks in advance.
Brian
chokes like how, not running properly? or just no power?
first thought i had was spark plugs. Check all the couplings on the intake, make sure yr not letting unmetered air in.
What size exhaust system you runnin???
Hi Neil,
She chokes like... well I guess you can hear the AEM sucking a lot of air for a brief second and then it comes to an abrupt stop... as if someone put their hand over the intake. ( That is when I am at rest and put my foot down). When I am moving she only likes to accelerate slowly. If I try to get her to race ahead, she almost 'hiccups'. You can feel the gaps in acceleration.
Brian
Many would argue 3" piping is too large for a cat-back. I wouldnt be able to explain how exactly 3" piping would contribute to your symptoms or even if its the cause.
I wonder if your IMRC is closing. Does it feel fine for a while, and then when you get on it once itll accelerate and suddenly be a dog past 3500rpm till you shut the car off and try again?
Discussion Starter · #10 ·
No. exactly the opposite. She chokes low and purrs at high revs. I just replaced the IMRC.
It feels like she isn't getting enough gas or something. Maybe too much air now. How can I retune the CPU to add more fuel... without paying $80/hr to a Ford dealership?!?
ever replaced your fuel filter? :shrug:
I wish i could be more help... i could think of a bunch of things that would contribute to top end loss, not randomized low end loss.
Buyer Beware
yeah sounds like your MAF is not liking the airflow.
you may have a vacume leak. check all your connections to make sure they are tight. make sure your iat & maf sensors are plugged in.
make sure all the vaccume lines ontop the upper intake manifold are intact.
Discussion Starter · #13 ·
All the MAF sensors are plugged in and there appear to be no leaks. IAT?? Please define.
If it is the MAF, what can I replace it with to work properly?
Seems to be fuel starvation, but it kinda doesn't make sense if you get good power top end. Replace your fuel filter, its around $10 at a autoparts store. That should help some, especially if your car has never had it replaced.
Discussion Starter · #17 ·
I agree about the fuel starvation, but there's plenty of air: AEM Short Ram intake.
I am leaning towards a 'more fuel (liquid)' solution. But how do I do that? CPU? MAF?
1 - 17 of 17 Posts
