1 - 3 of 3 Posts
I'm running a set of MB Quart 5.25's in the front doors. I plan to run them off an amplifier but I'm wondering if I can run wire to them or if I should just use the stock speaker wire in the doors and then splice the ends in the car and run it back to the amp. Any suggestions would be greatly appreciated.
BTW, I get some minor squeaks and rattles from the door and rear panels. I was thinking of getting a a pack of small balloons and covering all the snaps with them for a quick fix. Does anyone have a better idea?
Discussion Starter · #2 ·
The stock speaker wire going into the door is not that bad, but if you're going to run better wire anyway, you might as well do the whole thing. Don't splice wire if you don't have to.
1 - 3 of 3 Posts
