3rD BReKe LiGHT CoVeR QuESTiON
566 Views 15 Replies 9 Participants Last post by  PeDL2DaMeDL
just got one...i've heard some people sand down the actual 3rd brake light to take off the DOT NUMBERS or something...is that what most people have done? then clean it real good...stick it on after?
....just wanna make sure it goes on right the first time.
1 - 16 of 16 Posts
Yeah alot of members do that. It does make it look sleeker and fit better. Just be sure to make it as smooth as possible, and also clean it realllly well before applying the decal, cuz you dont want that corner to start to tear away from dust etc.
yeah, any imperfection will still show up even though it's covered by vinyl..
I AlSo EnJoY ThAt YoU TYpE EvERy ThReaD TiTLE LIkE ThIs... :tongue:
wouldnt recommend sanding the surface. Vinyl adheres beter to a smoother surface instead of a textured. If you must get rid of the DOT numbers, I would only do that immediate area nothing more.
Brian
Sand over it with higher and higher grit sandpaper to make it smooth. Finish it off with 1800, and it will look smoother than it did stock!
YoU mIgHt As WeLl bE tyPiNG iN cAPs
sorry, i had to say somethin since my nick is in alternating caps :p
You misspelled brake wrong in your title.
brake
not
breke
Thanks Guys - JeZzZ CaNT SaY WhAt I WaNT, HoW I wAnT To Or EvEn WhERe I WaNT To WiTHoUT SoMeOnE SaYiNG AnYTHinG...EvEN SpELL SomEThInG WRoNG By MIsTaKe AnD PeoPLe SaY SomEThinG!!!
JEEZ!, can't (I) say what I want, how I want, or even where I want to, without someone saying (something)...even spell something wrong by mistake and people say something.
That would be better, but of course that's a really long run on sentence.
Also, you had started the sentence with a Jeez! and that's not proper English sentence structure either.
Just messin man, no disrespect.
mERrY CHrisTMas!! PeDL2DaMedL :biggrin:
haha... you too
i have enough of english at the university...don't need it on here.
merry christmas
That is just simply painful to read. Why not just type it normally? I would think that it would be easier and faster.
well, i applied the 3rd brake cover, i sanded the most of the DOT numbers off, can still tell where they are if you look and there is a small bubble near the bottom, after i put it on my car it rained, hopefully it sticks well, should it?
has anyone ever had problems with the sticker or 3rd B. cover coming off/peeling off??
I have had mine on for two years now and no problems. I never sanded it or anything.
good to hear
1 - 16 of 16 Posts
