The mounting point for the IMRC box may have been different- It's identical mechanically, I just don't know that the cable will be long enough or too long...
The 3L IMRC has a cable that is about 8 inches long. The 2.5L IMRC is about 3 feet long.
Secondary linkage on the 3L pulls towards the front of the car; the 2.5 linkage pulls towards the firewall.
Long story short, you'd most likely need a 3L LIM and secondary linkage to use a 3L IMRC.
hmm....well the cable on mine is maybe 3-ft long....it's out in the car I'll check later......I'm doing plugs and wires tomorrow too....so I'll see if it works......it was an older 3L not the newer ones....the mounting point is the same on the front of the motor, not sure if the bolts line up though.....guess I'll check and see tomorrow.
