1 - 20 of 28 Posts
· Premium Member
List your mods and post pictures of your sheets so people can see what's possible with what! This thread is for NA motors. If you have a forced induction dyno then post it in the forced induction section.
The discussions should go to PMs or separate threads. This thread should be dyno plots only, to keep it readable. I'm pulling all the extra posts out.
Here is a quick list of what has been posted for those that just want to see the numbers. See the posts below for the mods.
timeless420..........SVT Contour.........2004 Ported 3L.................236whp....219wtq
Rickenbomb.........Cougar..................2004 Hybrid 3L..................227whp....206wtq
rb26deet32..........Cougar..................2004 Full 3L......................222whp....220wtq
Blackcoog............Cougar..................2004 Ported 3L..................220whp....200wtq
NVS SVT..............SVT Contour.........2003 Full 3L......................216whp....198wtq
Mond12345..........Cougar..................2002 Ported 3L..................216whp....191wtq
TRicker................SVT Contour..........2005 Full 3L......................213whp....212wtq
Redlineracer12.....Cougar..................2001 Ported 3L..................213whp....194wtq
SlowCat...............Cougar..................2005 Full 3L......................206whp....206wtq
StealthyWeasel.....Cougar..................2002 Ported 3L.................205whp....190wtq
Echoman..............Cougar..................200X Ported 3L.................205whp....178wtq
buckeyesvt...........SVT Contour..........2005 Full 3L......................203whp....209wtq
aboythatskates......Cougar..................2004 Full 3L.....................199whp....195wtq
Imadrid................Cougar..................2004 Full 3L.....................194whp....200wtq
Spridget...............Cougar..................2003 Full 3L.....................194whp....181wtq
Blackcoog.............SVT Contour 2.......2002 Ported 3L.................190whp....205wtq
Blackcoog.............SVT Contour 1.......2002 Ported 3L.................190whp....176wtq
rkneeshaw...........SVT Contour..........2004 Hybrid 3L.................189whp....186wtq
jaged...................Cougar.................200X Full 3L.....................185whp....180wtq
SicSE...................SVT Contour.........200X Hybrid 3L.................186whp....183wtq
nadthomas...........ATX Cougar...........2004 Ported 3L.................159whp....184wtq
· Premium Member
Discussion Starter · #2 · (Edited)
1999 Mercury Cougar
Engine Setup:
-2000 3.0L Duratec engine
-3.0 Oval port heads ported to match SVT UIM/LIM
-Exhaust ports port matched to Felpro gaskets
-Cleavite bearings
-Dual Mode Damper crank pulley
Performance Mods:
-MSDS Headers with jet hot coating
-MSDS y pipe attached to stock gutted cat section
-Borla dual exhaust
-SVT Cams
-Ported and polished SVT upper intake manifold
-Ported and polished SVT throttle body
-SVT lower intake manifold with counter sunk screws on butterflies
-CTA intake pipe with GMK Cold Air intake extension and large K&N filter
-Vitek plug wires
Cooling Mods:
-SVT oil cooler
-SVT radiator
-165 degree thermostat
Tuning Mods:
-SVT Mass Air Flow sensor
-SVT Engine Control Unit
-19lb return injectors
-Apexi air/fuel controller dyno tuned (SAFC)
Dyno Numbers: 220hp and 200tq
· Premium Member
1998.5 SVT Contour (Wife's Previous Car)
Engine Mods:
-2002 3L Sable Engine
-3.0L Oval port heads port matched to SVT intakes
-Dual mode damper crank pulley
Performance Mod:
-All SVT components (Upper intake, lower intake, and cams)
-Gutted precats
-Stock SVT intake box
Cooling Mods:
-Stock SVT parts (oil cooler, radiator)
Tuning Mods:
-Stock SVT ECU
-Stock 19lb injectors
-No dyno tuning
Dyno Numbers:190hp and 176tq
· Premium Member
1998 SVT Contour (Customer Car)
Engine Mods:
Performance Mod:
-Stock Precats
Cooling Mods:
-Stock SVT radiator
Tuning Mods:
-Stock SVT ECU
-Superchips SCT dyno tune by Chris Johnson of SCT
Dyno Numbers:190hp and 205tq
This is what my 1999 CSVT currently has in it's engine bay
Fully balanced 2004 Escape Shortblock * Ross Racing Pistons @ 11.5:1 Compression * PnP Oval Port heads matched to split port manifolds * Clevite main and rod bearings * 24# Accel Injectors * MSDS headers/y-pipe (Coated by Fireball Coatings in Shelbourne, Ontario) * CTA Motorsports 2.5 inch Catback exhaust with Dynomax Ultraflow SS Muffler * Performance Designs Underdrive PS and ALT Pullies * Performance Fords Optimized LIM * Performance Fords UIM Alignment Bushings * Optimized 65mm Throttle Body * CTA Motorsports Intake Pipe * Pro-M Bullet 75mm MAF * K&N RU-1785 Filter * 3inch Dryer Hose Running From Front Bumper To Air Filter * Magnacore Competition 8.5mm Wires * Motocraft AGSF22FM plugs * SCT XCal Tuning by Steeda.ca
This graph was before I added the MAX EH UIM and when a few issues were beginning to crop up (dying IMRC and oil getting sucked through the PCV into the intake) so it should be a bit better now.
Let's just say winter tires & +6deg celcius weather today made for lots of wheel spin.
Hey guys this is what Loganmotorsports did for me! I can't say enough about how much better the car feels and performs. I definately recommend their expertise! I have a 3.0 hybrid with P&P'd heads with 3L valves, SVT cams, UIM AND LIM ALONG WITH TB. Weapon R headers to highflow cat and Yodude dual exhaust setup,GMK CAI, oil cooler, spec stage 3 (overkill I know), short throw, fidanza flywheel, and of course the Loganmotorsports tune with Xcal2. I hope this pic works. Text Line Plot Parallel Font
I think this is what you needed this is the line with my max values off of the spreadsheet
EngRPM Torq Power Temp MAP Lambda AFR PCRatio Time Baro T.Effort Torque
lbft HP ーF PSI P/PC sec InHg lb lb-ft
6034 1020.713 205.017 62.4 0.63 0.84 12.35 1.05011 8.471 28.891 979.88 178.4463287
This thread is a GREAT idea.
1996 Ford Contour
Engine Setup:
-2004 3.0L Duratec shortblock
-2.5L SVT split port heads with SVT cams
Performance Mods:
-SVT intake manifold components (LIM/UIM)
-SVT exhaust with Magnaflow resonator
-Stock pre-cats
-Optimized SVT throttlebody
-Large K&N filter
Cooling Mods:
-stock radiator and cooling system
Tuning Mods:
-Stock ECU
-19lb SVT injectors
-ADC mail-order tune
Dyno Numbers: 189hp and 186tq
Engine setup:
2003 Sable engine with 3k miles
2005 Escape oil pan
DMD
Performance Mods:
SVT Cams
MSDS Headers, ceramic coated
160 T-Stat
Lightweight underdrive pulleys
NGK Iridium plugs
Fidanza 9Lbs flywheel
TruBendz 2.5" SS Magnaflow resonatorless
K&N in stock SVT housing
Tuning Mods:
X-Cal 2, tuned by SWPerformance
stock 2003 3L injectors
SVT MAF
194hp, 181tq
· Premium Member
3.0L Hybrid:
Tuned by Smokey's Dyno in the Akron/Canton area
My Modifications:
  • Custom ground 2.5L cams
  • Custom Cold Air Intake
  • SVT TB
  • Maximum Extrude Honed ST200 (SVT style) UIM
  • SVT ('01+ Cougar) LIM
  • 24 lb Taurus Split Port 3L Injectors
  • SVT heads with 3L valves retrofitted and 3-4 angle valve job (IIRC on the valve work)
  • MSDS Headers with ****ty MSDS Y-pipe
  • Custom 2.5 in exhaust with high flow mufflers and high flow cat
  • 3.83 Final Drive with Quaife Torque biasing/LSD/whatever the hell it's technically called
  • Fidanza flywheel
  • Centerforce Dual Friction clutch
  • Coil on plug Conversion
1999 Mercury Cougar
Engine Setup:
-2002 3.0L Duratec engine
-3.0 heads Port and Polished also Split Ported
-ST220 Valve Springs
-Cleavite Rod Bearings
-Dual Mode Damper Crank Pulley (DMD)
-5L8Z Oil Pan & Pick-up
Performance Mods:
-MSDS Headers - Y-Pipe with jet hot coating
-Trubendz Test-pipe (No Cat)
-Trubendz 2.5" Magnaflow Dual Exit Exhaust
-SVT Cams
-SVT UIM
-SVT TB Ported and Polished to 63mm
-SVT LIM
-Injen Short-Ram into a GMK CAI
-UnderDrive Pulleys - Power Steering & Alternator
-Ford Racing 9mm plug wires
-AutoLite XP Pro Plugs
Cooling Mods:
-SVT Radiator
-160 degree thermostat
-Metal Impellor Water Pump
Transaxle Mods:
-Torsen LSD
-Updated Shift Forks
-SPEC Stage 3 Clutch
-Fidanza Flywheel 9lb.
Tuning Mods:
-19lb Return Injectors
-XCal 2
Dyno Numbers: 216HP and 191TQ (SAE CORRECTED on a DynoJet)
'04 Ford Escape 3L motor
Tarus UIM
70mm tb
24# injectors
cai
borla cat back
I think I have 3L cams but I was told I had svt...What do you think?
3L oval port with PnP by Kinger
Swap numbers:
Before and after swap numbers:
Tuned by Warmonger! :cool:
2001 3.0L Taurus 24 Valve Shortblock brand new
2003 Taurus Cylinder Oval Port Heads – port matched to SVT Lower Intake Manifold (PnP)
4 angle valve job on intake and 3 angle valve job on exhaust
2007 Escape Oil Pan and pickup tube
SVT Cams, SVT Lower and Upper Intake Manifolds, SVT valvetrain
Borla SS Catback Exhaust
Trubendz SS Test pipe with Hi-flow Cat
MSDS Shorty Headers and y pipe
GMK Cold air intake extension w/ K&N
SCT XCalibrator 2 Flash Device with custom tune
Ford Racing 9MM blue plug wires
Autolite Finewire XP104 plugs
Power steering and alternator underdrive pulleys
SPEC stage 3+ Clutch
Findaza Lightweight Flywheel
Here's my dyno sheet:
Specs:
2005 Sable 3.0L engine
Gutted factory manifolds
Flowmaster Tru Bendz Cat Back
Short Ram Air Intake
Return to returnless conversion
Tuned by Akron Horsepower
AFR was a bit wacky without a tune..
And the time cut off just from tuning (4th gear from 2,000 RPM to 6,900 RPM)
That's it. I have more modifications (headers, CAI) to install here later and I'll take it to get retuned. Hopefully even better numbers at that time.
203FWHP 209FWTQ Have to drive to believe.
-Dom
Didn't see this thread before starting my own but heck I will post my graph here.
Engine Mods:
03 Escape 3L (Full 3L with SVT Cams)
Weaper R Headers and Y-Pipe
CTA Exhaust
42lb Injectors
Stock Intake Tube with K&N Filter
Motor bult and tuned by Nima (96BlackSE)
Aaron
Can I play?
Engine:
3L Escape block
3L Escape cams
98 SE heads w/mild port work & smoothed combustion chambers
Mods:
Custom CAI
70mm TB
3L split-port UIM - sans port divider
3L split-port LIM - gutted w/special port work
Gutted precats
Custom Y-pipe
Custom single exhaust w/cat
Stock SE PCM w/17lb injectors
183whp / 189 wtq
The numbers should get a lot better once I fix my detonation issue, (started around 5600 RPM on this run), then get busy with the PRP software.
So, half my plans fell through, and I fell short of my power goals because of it :rolleyes: .... Not to mention my cat is clogged and failing :facepalm: But I don't think I did too bad :evil:
My only power mods are:
FULL 2005 Sable 3.0L
MSDS Headers
"Optimized" Y-pipe
2.5" Trubendz Exhaust
SRI
206 whp / 206 trq
Finally got my cougar retuned with the SVT cams in there.
Mods are
-04 Escape motor
-Taurus 3L UIM/LIM
-custom fuel rail
-custom CAI
-70mm MAF w/ predator programmer
-Borla dual exhaust
-Msds headers y-pipe
-24lb injectors
-dyno tuned by Rob lasota
And I think thats it. Heres the dyno.
my 1998 contour SVT
untuned #'s here. mods list includes:
2005 sable long block
2005 Taurus upper and lower intakes
modified 2005 escape fuel rail (thanks blackcoog)
Nautilus fuel rail mod (-6 AN feed line)
MSD dis-4 ignition
9mm FRPP wires
WR stainless headers
WR stainless Y pipe
3 bolt flex pipe w/ 2.5" trubendz test pipe
2.5" trubendz catback
Lightning airbox
80mm maf housing w/ stock sensor installed
AC deleted
EGR deleted.
since this dyno: 90mm maf housing, 65mm TB w/ remote IAC, K&N drop in filter will tune next tuesday, i'll update the post with the new numbers :)
1 - 20 of 28 Posts
