Hi,
Is there a known Plant Photograph Green Light Automotive tire
Ford alternative to the later 2001/2 model rear top bump stop? From another model of the same era?
98-00 bump stop on left, later on the right..
Or is it a case of changing over the strut tops, bump stops and springs from the earlier model?
· Premium Member
Universal bump stops are fine. No need for model specific ones.
· Premium Member
Wait...are you talking about the spring seat? (black left, white right on your picture)
If that's the case, you can switch to the 99/00 parts from 01/02. You need a matched set of springs and spring seats. MK1 or MK2 Mondeo will work, but that's all we know of I think.
Plant Terrestrial plant Grass Font Audio equipment
HI,
Thanks for the replies - just the bumpstop - the shape on the earlier 'Mondeo' one is different do just curious if anyone has used the earlier one or which universal one can be used for 2001+ models
· Premium Member
Just measure the ID, OD, and length and get something that will fit. It's unlikely that you're spending a lot of time exercising your rear bump stops unless you're a racer.
When I did it 12 years ago, I used the bump stops that came with the replacement boots I bought.
My thread is too old to count on for accuracy anymore, but this is what I found at the time.
