New Info! as of 24-June-2020
$ 500 or off to the junk yard.
2000 Mercury Cougar
Spruce Green
2.5L V6 Duratec
Manual Transmission
250,000 Miles
1 owner
1 fender bender back in 2001
sold as is
pickup only - 48390 Michigan
DM if you want to schedule a test drive or have additional questions
Positives:
Engine runs great
Clutch is good
Transmission is good
Aftermarket air intake
Duel aftermarket exhaust
2010 Kenwood touchscreen radio
2001/2002 Instrumentation Panel (the original IP died about 4 years ago)
Vented front fenders
Carbon fiber hood
Carbon fiber side mirror trim
Carbon fiber gas door trim
Front headlight trim
Rear headlight trim
Front grill insert
Push-button start (still requires key placed in ignition)
Four aftermarket pioneer door speakers
Stubby antenna
Subwoofer install-ready, but not included
18in aftermarket Konig rims
Extra Positives - Not-installed/loose items that are included and MUST go with the car
Four additional rims with snow tires
Front strut tower bracket
Rear strut tower bracket
Extra aftermarket filter
Contour SVT intake manifold
Factory hood (minor rust/imperfections)
Factory front bumper (some imperfections)
Factory rear bumper (some imperfections)
Factory fenders (some imperfections)
Factory air filter
Negatives
Right rear side has brake like leak
Each body kit side skirt is hiding TERRIBLE rust damage. As in...there is no exterior metal behind the side skirts.
Engine light has been on for a couple of years. I believe that the air sensor on the aftermarket intake is loose.
There is a leak in the A/C system. If you refill it, it will empty within a week.
Driver door interior trim panel is a bit loose
Carbon fiber hood needs a good buff & polish
Rust is creeping by the antenna
Rear window defrost grid had a bad wire running to it, so I had to run one myself. It is visible.
Cougar emblem on decklid needs replacing
No jack nor tire iron
No rear license plate lights
Front headlight assembly has interior moisture marks and aging
I'll take the fenders if your interested in putting the factory ones back on the car and shipping the Z3's. (assuming they are in good shape)
Discussion Starter #3
Thank you for your inquiry! However, I am selling this as a complete package. I do not have the time or energy to part it out.
I have a pair, they need some work though. Came off a car I bought at end of last year.
Discussion Starter #7
2000 Mercury Cougar
Spruce Green
2.5L V6 Duratec
Manual Transmission
250,000 Miles
1 owner
sold as is
Positives:
Engine runs great
Clutch is good
Carbon fiber hood
Rear headlight trim
Front grill insert
Stubby antenna
Factory air filter
Negatives
Any way I can come up and look at the car this weekend?
