Hey All,
I have been battling an intermittent no start issue (when temp < 35F). Even when it does start and run fuel system drops to 0psi as soon as care is shut off. Have done lots of multimeter measurements and previously replaced parts (Pump, Filter, Fuel rail pressure sensor). Power and ground are good to fuel driver module and pump.
One question, on the returnless system I believe fuel pressure regulator is built into the pump, correct? I see this one part(see pics) in the fuel line prior to fuel rail sensor. It just has incoming and outgoing fuel line, no vacuum line or anything else. Does anyone know what this part is? I can not find anything calling it out in Ford Service manual or anything on internet. Would like to know what it is and what it does.
I really do not want to throw another fuel pump at this as the condition has come and gone prior to replacement of pump. There is something I am missing but can't figure out what, If anyone has any ideas on measurements to check driver and pump out that would be great. From what I can see the communication signals between fuel rail sensor, PCM, Driver Module and Pump are accurate to what fuel pressure is. Meaning low Volts when 0psi and up to 2.8volts when car starts and runs (39psi)
Thanks
Thanks
