For the center console, there are actually two where the ashtray is (1) remove the ashtray and its right there and (2) there is one behind the black piece surrounding the lighter. There is also two inside the armrest (if you have one) or under the plastic cup holder where the armrest would be. Also, there is one on either side of the console under two plastic caps up under the dash. You will more than likely have to remove the shifter handle (ATX, you need to cut the OD wires). That way you can remove the shifter boot (or plastic shifter piece, ATX once again) and also slide the boot for the E-Brake. You will need to pull the E-Brake up to get it off.
Also Be careful not to crack the console (it likes to crack right at the bend, well atleast mine did)
Jester
