1 - 20 of 21 Posts
List your mods and post pictures of your sheets so people can see what's possible with what!
Edit by DanG: The discussions should go to PMs or separate threads. This thread should be dyno plots only, to keep it readable. I'm pulling all the extra posts out.
Here's mine
I hit a 172FWHP N/A
SVT UIM,LIM,TB, 19lb injectors
Titan CAI
Underiven crank pulley
MSDS headers and y-pipe ceramic coating
Tru-bendz test pipe
flowmaster-< tru-bendz exhaust
S-AFCII
VCN-1000 running a 50 shot
basic bolt-ons
Fully gas flowed, ported and blue printed
Uprated oil pump
Uprated water pump
Uprated fule pump
Weapon-R Headers
Custom duel exit Blue Flame exhaust system
All the CATS were removed
Fast Road CAMs
Standard ECU, injectors and air intake (as all these were being ripped out when the Pro charger went on 1 week after this graph was done)
Paul
Buyer Beware
I have long since lost my dyno Sheet. When I dynoed my cougar back in 03 i Put down the following
155whp.
150wtq
Mods at that time:
Polished GMK CAI
MSDS headers & ypipe
Gutted and modified OEM cat with 2.25" exit
Flowmaster dual exhaust (truebendz) 2.25 inlet/2.5" outlet
Denso Iridium plugs
SVT UIM & LIM & TB
stock injectors and tuning.
I plan on dynoing again very soon with my newer 2.5L setup.
This is from over a year ago.......BEFORE the 3.0L :tongue:
Mods:
SVT UIM, LIM, T/B
Gutted precats, testpipe, True Borla split rear exhaust
GMK carbonfiber CAI :cool:, Ford Racing plugwires, NGK splitfire plugs
The pull in RED is 87 octane, the pull in BLUE is 93! Been using 93 eversince:biggrin: If you can't read, it says 163.3 HP & 159.3 TQ
Here is mine. I think there was something funny going on with my engine when it was done; in particular I wonder if the alternator started causing problems at the top end (though it certainly doesn't look it).
This is a completely stock MTX V6 Cougar except for a K&N Drop-in Filter and Ford Racing 9mm plug wires. The plugs and wires were new as of a few months before this dyno was done. The UIM and LIM had never been cleaned and the car had over 60,000 miles on it.
(Not a real good graph, I know. I'm working on producing a better one.)
First we crack the shell!
Confirmed by DanG my 2.5L was a factory freak. Dyno'd at CF 2003 I pulled DynoJet IIRC.
153 whp
147 wtorque
Mods at that time included:
KKM filter with BAT gooseneck
SVT UIM and TB
Bosch Platinum +4 plugs (In good condition when removed :crazy: )
Trubendz Flowmatster AS dual exhaust
Dyno will be posted when I can get it scanned.
This car USED to belong to my brother--he says he had some high compression pistons put in.
What I have put in
SVT:
*UIM
*LIM
*CAMS
*GEARS
Unorthodox Racing:
*Pulleys
ADC:
*2.5 NA Chip
Zex
*50 shot
id say that im doin allright...
199 fwhp
190 fwtq
here's what i got...
GMK CF CAI, SVT TB, SVT UIM,
Unordx pulley, Viteck racing wires,
Weapon R headers, Yipipe, custom 2.25 full catback exhaust
Stage 1 spec clutch & Lightweight Fidanza Flywheel...
... just call me bolt-on-wonderboy.. lol
i don't have any tunning at all
here's my numbers...
HP between 152.1 & 154.4
TQ between 143.5 & 146.8
.. and some other weird graph...
HP
TQ
... other
Not a cougar but my 1998 SVT Contour. KKM, Gutted precats, Magnaflow exhaust, modded stock y-pipe. Hehe and 220K on the odometer when the runs were made :) I'm now at over 250K and still going strong (knock on wood)
As for mine, i was hoping for alittle more hp but after the tune it came to
150hp at 6200rpm and 140tq at 4300rpms. As for mods to the engine I have svt uim,lim,tb,cams,injectors,cai,msds headers, y-pipe, flowmaster exhaust,xcal2 tune to 93 octane and thats it.o yeah, its an auto.
Dyno'd 01 ATX Sport Pkg. Coug on a DynoJet today
-K&N Intake Kit
-Replaced muffler w/aftermarket "rice" one
131.91 hp
135.59 tq
dont really know if there's a need to even put the dyno graph up...just needed a baseline run before anything big goes on...
Just got mine dyno'd today on a Mustang Dyno:
167.0HP @ 5957...189.0 WCF
171.3TQ @ 4418...193.9 WCF
2.5' cat-back, Weapon-R air filter
Kinda thinking I'd push a little more, seeing those WCF's give me hope tho.
well after 5 months of work on my prototype turbo kit and a big thanks to joey on
11psi on a all stock 2.5 no svt parts
278whp:biggrin:
did get an hp on 13psi.
I don't have adyno sheet like yours, I just have the one that came with my car.
It's a naturally aspirated 2.5l, runs with a Ford ecu and the emissions have been taken off. I think its okay and it goes quick enough, but it is a bit loud, :evil:.
Eric
155whp.
150wtq
Mods at that time:
Polished GMK CAI
Denso Iridium plugs
SVT UIM & LIM & TB
I had this car on a dyno over the weekend and it is down to minimal mods as follows.
MSDS Headers
BAT Pipe
Open air filter
93 octane tunes
new autolite double plats
FMS 9mm wires
Car has stock exhaust with cats and all I was actually impressed.
According to the Dyno operator, he said that I left a lot of power on the table because it appears that the PCM makes the car go super rich at around 5.3k rpm. He believes it's because the PCM thinks the CAT is burning up since it sees a long haul at WOT, so it dumps gas at it. Noticing the Cougars dyno'd that day, those with SVT PCM's had almost straight line A/F. They too also went rich at 5.3k rpm but it was almost negligible. A Cougar with the same power mods but with the SVT PCM and 19lb injectors ran 159 hp.
I need to get a SVT PCM, 19lb injectors, and some new plug & wires (it dyno'd on the originals) lol. 89k miles.
MODS: MSDS Headers + Y-pipe, K&N SRI, Trubendz dual Borla.
Best of 3, 146.4 hp, 140.0 wtq.
1 - 20 of 21 Posts
