Yeah, I was going to mention that, but it requires bastardizing rare SVT cams, something I would not be able to toOriginally posted by: Buckshot77
Actually you can use the SVT cams with the 99 style heads, just cut off the waterpump drive and use an electric waterpump system.
Rick
Yeah but isn't it a pain to get the electric waterpump working correctly (fabricating pieces and stuff)? Plus the whole taking forever to warm up your engine problem. Then again if you're gonna make a hybrid I guess you're not too worried about having to go the extra mile.Originally posted by: Buckshot77
Rick
No kidding. I think I have 14+ hours into just one 2.5L head, and I havent even started on the comb. chamber or bowl work. With a set of 2.5L and 3.0L ('99 I believe) heads sitting next to each other it appears that the 3.0 would flow better with less work. The exhaust ports of both heads, in stock form leave something to be desired. I will probably end up porting/polishing both sets of heads, just to see what is possible with the 3.0 as im using 2.5 heads on my project. These will not be flow benched though, so there may very well be inconsistencies in flow between ports. So if anyone wants a set of 99? port/polished bare heads hit me up with a PM. :biggrin:I won't lie to you. Porting Duratec heads is very tedious and meticulous work; not to mention extremely time consuming.
