As I gradually slip into the world of "need for control over ECU/PCM," I find that I have more questions than answers. So naturally I feel right at home.
So, I know there are those of you running MSD DIS-2 to control ignition, and running eManage to control fuel maps. And there are still others running dedicated burn chips specific to your cars.
So what's the best for overall control of your engine? I don't know much about tweaking myself, so I'm kind of scared I'll F*#K something up and blow my pistons through the hood of my car. I'd like the control that comes from in car intervention, but I also want to pull the speed and maybe the rev limiters.
I also want full functionality of the ECU/PCM. You know I've been told that some of the aftermarket stand alones don't have input/output for all the functions of your car, and you end up having to "mask" a lot of warning lights and codes.
Can you run something like an aftermarket piggyback AND a chip to pull the rev/speed limiter? Or get a chip burned to just pull the rev & speed limits and use external controllers for everything else?
Just curious...
Just curious...
