2.0 Zetec custom turbo install almost completed.......
Well, my turbo install is almost completed. I'll give a quick run down for those that may be interested.
Day 1:
-Removed the stock exhaust manifold, catalytic converter and exhaust system up to the two bolt flange.
-Installed turbo manifold and turbo charger.
-Fabricate and install turbo coolant lines.
Day 2:
-Fabricate and install turbo oil feed line.
-Remove oil pan and fabricate fittings for oil return line.
-Fabricate intercooler charge piping from the turbo compressor outlet to the intercooler inlet.
Day 3:
-Fabricate intercooler charge piping from the intercooler outlet to the throttle body.
-Fabricate the stand-off and flange for the by-pass valve (BOV).
Day 4:
-Fabricate turbo intake piping from the turbo inlet to the MAF sensor/air filter.
Day 5:
-Fabricate pipe fitting for BOV vent hose to turbo intake pipe.
-Fabricate turbo down pipe.
All I have left to do is to fabricate the tie-in pipe for the external wastegate to the turbo down pipe, install the larger fuel injectors...............then, pull out all of the piping for painting with high temperature ceramic paint. Whew..........almost done.......
:biggrin:
Day 1:
Day 2:
Day 3:
Day 4:
Day 5:
:biggrin:
